How long has the Passat 132 TSI been around? Has anyone on here had any issues with its DSG?
Passat 132 TSI DSG
Same 7 speed DSG as in the Mk7 Golf. No major reports of issues. The earlier 7 speed DSG gearbox in the Mk6 Golf and B7 Passat had issues.Originally posted by Janko View PostHow long has the Passat 132 TSI been around? Has anyone on here had any issues with its DSG?
Only the 206TSI gets the Adaptive Chassis control. The R-line option on the 132TSI Comfortline gives you sports suspension with 15mm drop over the standard 132TSI.Originally posted by momall View PostDoes the R pack includes Adaptive Chassis control?
Still thinking...Originally posted by momall View PostThanks. Thinking of replacing the B7 TSI with the 132comfortline plus luxury pack and R Pack...MY18 VW Passat Alltrack Wolfsburg Edition + Panoramic Sunroof + some extra goodies... (Pure White)
Test drive the normal 132 TSI and the Rline version on a bumpy road and decide which one suits you better.If your regular route is not agreat road you might be better off minus Rline.Originally posted by momall View PostThanks. Thinking of replacing the B7 TSI with the 132comfortline plus luxury pack and R Pack...
Took the plunge and am happy with the R-Line. Its does not come with Adaptive Chassis control. Suits me fine though.Originally posted by momall View PostThanks. Thinking of replacing the B7 TSI with the 132comfortline plus luxury pack and R Pack...
Interesting, the ride is a lot more comfortable than my MY 13 TSI Jetta with Sport pack.
I got 8L with R19 wheels, but on eco mode all the time though. Just because coasting is only available on Eco mode, it made a huge difference. I got as low as 7.5L at night when there's only few traffic from work to home.Originally posted by zzc2010 View PostAveraging around 10L with R19 wheels.
Current: MY16 132TSI | Luxury | R-Line
MY14 C250 W205 | Command | Vision | Exclusive | Seat Comfort
MY13 A200 W176 | Command | Vision | Exclusive | Seat Comfort
I will switch to ECO mode then.Originally posted by rave75 View PostI got 8L with R19 wheels, but on eco mode all the time though. Just because coasting is only available on Eco mode, it made a huge difference. I got as low as 7.5L at night when there's only few traffic from work to home.
I just wonder if ECO mode puts too much pressure onto the DSG for saving fuels.
Never want to break the DRY DSG again.
That I don't know. As far as I know, creeping (slowly moving during traffic jam) put a stress on the clutch and will cause premature wear, just like when you drive manual. So you better give a distance between you and the front car then accelerate. Holding the throttle while on the hill to keep it from rolling backwards is a big no no too. You will need to replace the clutch plate anyway sometime in the future but don't make it sooner!Originally posted by zzc2010 View PostI will switch to ECO mode then.
You will see the benefit of ECO mode when the road is sloping down, that's when you need to take of your foot from the gas pedal. You will see ECO symbol on the lower right of your screen when coasting is on (mine is not virtual display). Coasting will prevent engine braking, disengage the clutch, the RPM will sit at idle speed (around 800 i think) and use the momentum of the car to roll forward. When you press the gas or brake, it will engage the clutch again and deactivate coasting mode.
I imagine if the road is flat or uphill, you won't really see the benefit of ECO mode. I travel from Parramatta to Chatswood for work (around 25km a day) so I've saved quite a lot in terms of fuel expenses. At night when there's hardly any traffic, I could get even 7L and in the morning it is close to 8L. My long term average sits at 7.5L now. Hopefully this helps.Last edited by rave75; 03-05-2017, 11:46 AM.
That's very helpful.Originally posted by rave75 View PostThat I don't know. As far as I know, creeping (slowly moving during traffic jam) put a stress on the clutch and will cause premature wear, just like when you drive manual. So you better give a distance between you and the front car then accelerate. Holding the throttle while on the hill to keep it from rolling backwards is a big no no too. You will need to replace the clutch plate anyway sometime in the future but don't make it sooner!
Thanks.
