Hello,
My Passat B8.5 is equiped with factory A5 front camera 2Q0980653.
I am planning to upgrade the firmware of factory front camera (2Q0980653 HW:H13 SW:1030) because I am disappointed by the Matrix LED lights performances.
They do a very good job at night, but only with curved roads.
The A5 camera is a factory camera (Lane Assist, Front Assist, Light Assist with Matrix LED lights all working with no issue).
Will Component Protection appear after firmware upgrade (from 1030 to 1423 for example) ?
Current config :
SW:2Q0-980-653 HW:2Q0-980-653 --- Frt Sens. Drv. Assist
Component:MQB MFK 3.0 H13 1030
EV_MFK3ValeoMQB,005035,EV_MFK3ValeoMQB_005_VW27.ro d
This is what I have understood, for the firmware upgrade of 2Q0980653 from 1030 to 1423 :
Is there any calibrations to do after the firmware upgrade ?
Thank you.
Update :
Current config :
- Save codings/adaptation of current A5 config (2Q0980653)
- Flash BootLoader 0220 (?)
- Flash Firmware 1423 (?)
- Write Dataset (?) for Passat B8
- Check/update coding/adaptations
Thank you.
Update :
- It seems that 2Q0980653 has several HW : A/B/C/..
- There are many different bootloader/datasets, according to the hardware/software configuration of the car (eg. LED High Beam Assist, IQ.Light Matrix LED, etc.), so it is very difficult to find the correct dataset.
- Any wrong firmware/bootloader/dataset update may lead to camera brick
