What do I need to update my TPMS?
  • What do I need to update my TPMS?
    I have a 2016 rline Passat that has this
    and I want to have what my wife has in her 2019 Tiguan
    What do I need to update my TPMS? I got a flat tyre the other day and it wasn't too obvious which tyre was going flat.
    Your Passat looks to have indirect TPMS; this uses the ABS wheel sensors to work out if any tyres have gone flat.
    To get the display of each tyre's pressure, your would need to retrofit the direct TPMS system.
    Parts that would be needed
    5Q0 907 273 B - TPMS Module
    3G0907538 - Bracket
    4 x 5Q0907275F - Wheel sensors
    4 x 3AA998275 - Valve stem
    Wiring harness.
    Coding via scan tool.
    Kudatec does a kit to do this.
    Tire Pressure Monitoring System (TPMS) for VW Passat B8
      Thanks. Can the coding be done by obdeleven?
        If you go to the link you would find the answer
          Hey OP, curious if you ended up doing this retrofit? Looking to do it on mine!
            Also curious to find out more about it =)
            I've bought all the parts to do this on my Arteon - just sorting out some other upgrades and also waiting to find the time/courage to give it a go
              I would have done it but since I had to get my wheels fixed and painted due to the pot holes and me accidentally water blasting the heck out of them, I'll wait until I get back from going overseas.
