Has anyone else had there alternator go at 100k . Auto electrician said it’s very rare and cost so far for replacement is $2500 nzd to replace
206tsi alternator fail
I had an issue with the factory battery dying so I replaced with one from battery town. That also died, suspected alternator but just ended up getting one from VW New market with it being coded and worked fine. No issues except the steep price.
Have you tried replacing battery?2018 B8 Black 206TSi Estate - Thule Roof Racks - Tow bar - Dechrome - REVO Stg1 ECU/TCU - R600 Intake - CTS turbo muffler delete - CTS inlet pipe - CTS 200 cell catted downpipe w/ OEM resonator delete
2009 B6 Black 2.0TSi Estate
Follow my instagram for the build @rogs_passatb8 (if... you wanna...)
My 2017 Wolfsburg is in the dealer today and has had the same diagnosis. I started noticing something getting noisy under the bonnet.
Mine has 58,000Kms
Luckily as it was registered in January 2019 it has the 5 year warranty.2023 MY22 Arteon R-Line Shooting Brake
2020 MY20 Polo GTi
Previous - 2019 MY18 VW Passat Alltrack Wolfsburg Edition
Originally posted by StefanVXR8 View PostMy 2017 Wolfsburg is in the dealer today and has had the same diagnosis. I started noticing something getting noisy under the bonnet.
Mine has 58,000Kms
Luckily as it was registered in January 2019 it has the 5 year warranty.MY18 VW Passat Alltrack Wolfsburg Edition + Panoramic Sunroof + some extra goodies... (Pure White)
Originally posted by ope126 View PostLet us know the outcome!!!
Stef2023 MY22 Arteon R-Line Shooting Brake
2020 MY20 Polo GTi
Interesting... I have discolored (clouded) chrome window trim above the gas flap on my Arteon too... must be caused by fumes or something.2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
The Chrome Window trim can be easily brought back to new with the following products; California Custom Aluminium Deoxidizer (Step 1) Aluminium Deoxidizer – California Custom Products and followed up with Autosol Anodised Aluminium Polish Anodised Aluminium Polish 75ml - Present on every window frame!MY18 VW Passat Alltrack Wolfsburg Edition + Panoramic Sunroof + some extra goodies... (Pure White)
Originally posted by ope126 View PostThe Chrome Window trim can be easily brought back to new with the following products; California Custom Aluminium Deoxidizer (Step 1) Aluminium Deoxidizer – California Custom Products and followed up with Autosol Anodised Aluminium Polish Anodised Aluminium Polish 75ml - Present on every window frame!
Thanks - these arrived today. Will see how it goes
Update:
Couldn't get it to work. Did the deoxidizer then polish 3 times and it was still cloudy. Even broke out the Dremel polishing attachment to see if it'd help.
Every time I got a little shine (still not as good as original) it'd cloud back up at the first sign of moisture (even from breathing on it) and was worse than before.. I think the metal (aluminum?) just immediately oxidized.
I then went into experiment mode and tried a bunch of things with similar results... I even mixed some carnuba wax with the anodized aluminium polish to try keep it coated, but that was only slightly better.
Before:
After (deoxidizer + polish x3):
Last edited by nermal; 08-07-2023, 01:11 PM.2018 Arteon R-Line - Black, Sunroof, Dynaudio, 20" Wheels, RacingLine: Stage 2 ECU+DSG|380mm BBK|Intercooler+Hoses|Oil Cooler|R600 Intake|Adjustable Front Droplinks|Dogbone Insert|Subframe Brace+Alignment Kit|Propshaft Alignment Kit, Milltek: Zirotec Downpipe, Harding: Front+Rear Sway Bars|Rear Droplinks, Other: OSRAM Dynamic Indicators, EvcX Throttle Controller, 034 (RED) Coil Packs, Various Carbon Bits
Originally posted by godspd1 View PostI had an issue with the factory battery dying so I replaced with one from battery town. That also died, suspected alternator but just ended up getting one from VW New market with it being coded and worked fine. No issues except the steep price.
