R36 wagon brake "upgrade"
  • R36 wagon brake "upgrade"
    Hi all,
    So my rear brakes are shagged and I am going to take this opportunity to change to ATE ceramic pads. The ATE website suggests that you change the rotors when swapping to the ceramic pads and I'm considering the DBA Street Series T2 rotors.
    DBA Street Series T2 Slotted Brake Rotor Suit Rear VW Volkswagen Passat 3.6L R36
    I'm looking into these for the added performance and sportier styling. My concern is they might be noisy. Does anyone have any experience with these rotors?
    TIA
    Dom
    Sent from my SM-G955F using Tapatalk
    Interested to know as well
    I have the exact parts combo ready but the factory discs and pads are still going strong...
    2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
    2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
    2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
      Originally posted by Domatron View Post
      Hi all,
      TIA
      Dom
      Hey mate i am getting ate pads with drilled rotors next week Zimmerman rotors tho not t2 but should be similar will be posting results in the alltrack and mark 7 brake forums will make sure i mention noise levels for you
      2017 Golf Alltrack 135tdi All options
        I'll look it for your post!
          T3 front w ate ceramic & T2 rear w ate ceramic.
          - Didn't notice any extra noise personally. (Maybe a tiny noise directly following a car wash; wheels/brakes subjected to pressure washer)
          - Noticed less brake dust, but definitely still there
          - Have not driven hard enough to notice incremental performance benefits
          Hth.
          Sent from my SM-N950F using Tapatalk
          No more running wild...
            Hth.
            Perfect thanks for the info!
              T3 front
              T2 rear
              Remsa semi ceramic pads front + rear
              Still dusty, no real noticeable noise, takes a few hard brakes when cold to bite but otherwise pretty good.
              R36
                Hi all,
                TIA
                Dom
                You shouldn’t have noises with the DBA rotors and ATE Ceramic pads, as long as fitted correctly.
                Performance Tunes from $850
                Wrecking RS OCTAVIA 2 Link
                  Yep go for it got ate front and rear now no noise at all that's with Zimmerman drilled rotors
                    Originally posted by basic View Post
                    T3 front
                    T2 rear
                    Thanks!
                      Great news! Would you mind sharing where you bought your gear crom and how much it cost?
                        Np mate
                        The fronts in 340mm disc were 221 each side
                        And the pads for both were 224
                        Back rotors in 310mm were 165 each
                        Pafs for back were 145 a set
                        Be aware that the feel of ceramics is different not as much bite straight up but still pull up well
                        I also have a longer pedal travel atm as car is relearning the new bigger calipers so is a different feel
                          Np mate
                          Cheers for that. And where did you get them from?
                            Ah sorry mate
                            Volkstech in west heidelberg is the shop i used rob and manny were great
                            They are always very busy so make sure you book early
