The rocking-VW-badge boot opening switch is starting to play up. Sometimes takes 2 or 3 attempts to make it work. The button on the remote works every time. Has anyone had a similar problem? Was a replacement part or just an adjustment required to fix it?
Anybody had trouble with the boot opener?
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s -
Thanks Umai Naa!! I appreciate your help. I'll try to verify which it's most likely to be by holding the boot lid very still whilst moving the badge.
I assume the badge must be replaced from the inside with the lining removed or lifted?2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
