Steerring wheel strange feel..
  • Steerring wheel strange feel..
    I do not know if someone had same issue...basically, maybe once or twice per day when driving car l got feeeling in steerign wheel like driving in undergroud garage with tyre sretching noise...no vibrations or anything else...never happed before just startwd recently...
    Ideas?
    Sent from my D6503 using Tapatalk
    2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
    Let me confirm that I got your query correct.
    That you feel that sometimes when you are driving on the road, that your car is not turning in proportion to your steering input?? That the front tyres lack grip??
    If so then I would check your tyres especially the front for tread depth and inflation pressure , as it sounds like you maybe understeering due to lack of front end grip.
      Go around corners a bit slower
        Only at low speeds in carparks?
        Normal. Look up Ackerman angle.
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
          Actually, never happens around corners...
            Thank you, maybe is time to check tyres....i asssume steetlring wheel is electrical but still need fluid. Is possible lack of fluid can makes issue?
              No fluid. It's totally electric.
              '01 Beetle 2.0
                Done wheel and tyre aligment at bob jane. No issue for far...
                  This is what I would have suggested to try first. You will probably be right from now on.
                  MK4 GTI - Sold
                  MK5 Jetta Turbo - Sold
                    Thank you, i follow up your sugestion...
                      Again me, again same issue...now i am thinking brake pads ( i am.due to change nex service)...happens at low speed eg. On roundbauts etc...no shaking, no vibration but squeeking feels...
                        If you have had your alignment done at Bob Jane, can I assume that your tyre tread depth is OK??
                        How old are your tyres ( in KMs and age )??
                        What brand are they??
                        Have you discussed your problem with the Bob Jane techs?? Taken them for a test drive??
                          Michelin pilot sport 3. Two year old. Done 35.000 km. Technician told me i am good for another 15.000 km. Wheel aligment done. Front tyres put instead back. Got new tyre feeling. Issue happens intermittently...hard to replicated...
                            Sorry but I have run out of ideas.
                            It still sounds like understeering to me.
                              OP said that it doesn't happen when cornering, which would seem to make understeer unlikely.
                              OP - Is there any pattern you can discern? Does it happen on particular road surfaces? It's not uncommon to get a bit of rubber squeaking when passing over tram tracks, for example.
