3.2 FSI faults
  • 3.2 FSI faults
    Hi there. Do you have any ideas where to start to look for the source of below? Engine runs smooth and nice as usually... Thanks.
    Component and/or Version: P3.2-FSI-EU4 G00 1086
    Software Coding: 0000175
    Work Shop Code: WSC 00028 028 00001
    VCID: 62C182D4BDC5852E08-8036
    2 Faults Found:000373 - Fuel Trim; Bank 2
    P0175 - 008 - System Too Rich - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 0
    Fault Frequency: 47
    Reset counter: 255
    Mileage: 242932 km
    Time Indication: 0
    Date: 2016.07.19
    Time: 06:57:13
    Freeze Frame:
    RPM: 609 /min
    Load: 32.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 33.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.589 V
    000370 - Fuel Trim; Bank 1
    P0172 - 008 - System Too Rich - MIL ON
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 41
    Reset counter: 255
    Mileage: 242932 km
    Time Indication: 0
    Date: 2016.07.19
    Time: 06:57:19
    Freeze Frame:
    RPM: 609 /min
    Load: 32.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 34.0°C
    Voltage: 13.589 V
    Any and every fault from VCDS should be googled and run back to the Wiki.
    16556/P0172/000370 - Ross-Tech Wiki
    It gives so much, makes me look good regularly.
    Check the fuel trims, probably block 032?
    Probably out by miles.
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 47
    Reset counter: 255
    Mileage: 242932 km
    Time Indication: 0
    Date: 2016.07.19
    Time: 06:57:13
    Freeze Frame:
    RPM: 609 /min
    Load: 32.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 33.0°C
    Voltage: 13.589 V
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 41
    Reset counter: 255
    Mileage: 242932 km
    Time Indication: 0
    Date: 2016.07.19
    Time: 06:57:19
    Freeze Frame:
    RPM: 609 /min
    Load: 32.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 34.0°C
    Voltage: 13.589 V
      Thx. I have red that Ross Tech already, just thought someone already went through such thing... Looks like I will not be able to fix it myself. Anyway I will let you know the result of fixing, may help in the future.
