Hi Everyone,
If anyone can help me by looking over this autoscan result of a B7 Passat that I had a look at today.
There are a few fault codes I am a little concerned about, not being up to date with the newer generations of VWs.
I have removed the non faulty modules output.
Code:
Thursday,28,January,2016,17:41:16:07510
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
[url=http://www.Ross-Tech.com]Ross-Tech: Home[/url]
Mileage: 33750km-20971mi Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 25 2E 36 37 3C 42 44
46 47 4C 4F 52 53 55 56 61 62 6C 72 77 A5
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (0-32-BWS ) Labels: None
Part No SW: 03H 906 023 L HW: 03H 907 309 A
Component: 3,6 FSI EU5 H04 2758
Revision: MFH04--- Serial number: VWZCZ000000000
Coding: 001D0012246600000000
Shop #: WSC 00028 028 00309
ASAM Dataset: EV_ECM36FSI01103H906023L 002011
ROD: EV_ECM36FSI01103H906023L.rod
VCID: 2B5502E742186666F4-807E
5 Faults Found:
4330 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Freeze Frame:
2670 - Throttle Position Sensor (G69)
P0122 00 [096] - Signal too Low
Freeze Frame:
2674 - Angle Sensor 2 for Throttle (G188)
P0222 00 [096] - Signal Too Low
Freeze Frame:
4219 - EVAP Emission Control Sys
P0441 00 [096] - Incorrect Flow
Freeze Frame:
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BL HW: 3AA 614 109 BL
Component: J104 C2 450M VED6 0024
Revision: --H07--- Serial number: 00000005749740
Coding: 0116644
Shop #: WSC 00028 028 00001
VCID: 78FFEDAB0BCE1DFE49-802C
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 52
Reset counter: 214
Mileage: 32997 km
Time Indication: 0
Date: 2016.01.18
Time: 15:53:31
Freeze Frame:
Speed: 87.0 km/h
Hex Value: 0x0001
Bin. Bits: 00000000 00000000
Voltage: 12.75 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 D
Component: RNS-MID H70 4120
Revision: AB001001 Serial number: VWZ6Z7M7179049
Coding: 04050002010000A00010
VCID: 2F6D16F77E001A46D8-807A
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V5 7679
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 2
Reset counter: 254
Mileage: 29293 km
Time Indication: 0
Date: 2015.08.10
Time: 12:42:58
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0005226079
Coding: 0013B6
Shop #: WSC 00028 028 00022
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 36632393895A2B8E9B-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0502
Serial number: 00000002996772
Coding: 010290
1 Fault Found:
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 32472 km
Date: 2016.01.14
Time: 16:38:54
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 254
Mileage: 29293 km
Time Indication: 0
Date: 2015.08.10
Time: 12:42:58
End-------------------------(Elapsed Time: 04:17)--------------------------
