R36 leaky water bottle
  • R36 leaky water bottle
    Hi all,
    The water bottle or pump or pipe or something to do with the window/headlight washer system is leaking on my wagon. By the looks of it I have to pretty much deconstruct most of the front end of my car to get at the problem area.
    Has anyone had any experience with this issue before? Do I actually have to take everything off the front or is there an easier way?
    If you remove the black plastic lining inside the guard on that side (8 x Torx-25 screws), you will have reasonable visibility of some of the bolts that attach the washer bottle plus the electrical connector to the motor and the hose for the water. This may not allow you to remove the washer bottle, but you could at least check the electrical & hose connectors and get an idea of what's involved.
    You may be shocked how much rubbish accumulates behind these plastic inner guards, so it's probably a useful exercise to give things a clean anyway.
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
      Thanks. I got it done in the end without completely removing the bumper. Just enough to peak in and see what was going on. It was just the small hose that goes up to the windscreen sprayers that had popped off somehow. It looks like there is another leak in this hose but it is behind the front wheel under the quarter panel and I couldn't be arsed right now...
        Mine is leaking from the rubber grommet on the washer pump. Only lasts a couple of days before its emptied itself, major pain! I took the whole front bumper off to check it an even then it still looked difficult to pull the whole bottle out...
        2017 VW Tiguan 140TDI Highline
        2012 VW Touareg V6 TDI
        1985 Mercedes-Benz 380SE
