R36 seats into a 2006 Passat FSI 4 Motion?
  • R36 seats into a 2006 Passat FSI 4 Motion?
    Hi all,
    Just wondering if 2008 R36 seats will bolt into a 2006 passat?
    Or if not, are there other options for aftermarket seats that are not crazy expensive ... looking for better support and comfort.
    cheers,
    Jon
    Should be a straight swap. Also depending on if electric or not. There is a chance the airbag plug may be different too.
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
      thanks mate I'll give it a go.
        No probs. Physically the same mount points.
        You might have to swap the airbag plugs. It's quickest / easiest to cut the wires 100mm back from the plug and solder / heatshrink.
        The little black plug for the seat belt sensor should be the same.
          Where did you find the seats?
            I am looking to sell my 2008 R36 front seats and put some other lightweight hugging seats in. Has anyone ever tried this ? I had a look under the drivers seat and there is a whole lot going on such as wiring/looms, control unit, mechanisms etc. EVO 7 or 8 seats may be a possibilty.
