R36 LED Wing Mirror Puddle Lights Install with Pics
  • R36 LED Wing Mirror Puddle Lights Install with Pics
    Well,
    As promised, my next instalment in the LED upgrading of our R36 is upon us. This time around it is LED puddle lights. I purchased these from the following website ( 2X Error Free LED Side Mirror Puddle Light VW Golf 5 MK5 MKV Passat B6 Jetta EOS | eBay ). Now I was a little dubious in spending that sort of money but it actually was cheap compared to some ebay store prices. Now the install was pretty easy really. All you do is gently push the mirror forward towards the front of the car. It will let go and you will see the end of the puddle light along with a little torx screw. All you do is unscrew it and get a small flat head screw driver and pry open the light using the vertical edge closest to the front of the car. Be gentle and the light will pop out. The original light is a T10 bulb pushed into the housing. Simply pull the rubber stopper away from the light housing and you will see the T10 bulb sitting there in its housing. Simply remove bulb and push the end of the new LED assembly into the socket. Then push the wires into the mirror housing and push the LED assembly back into the mirror and replace the torx screw. Very easy mod. Probably took 3 minutes per side. The results are very impressive. I would say that the light output is about three times brighter than the standard yellow bulb and it is very white. If you wish not to install the LED's you could simply buy blue T10 bulbs and you would get a whiter light than standard but you won't get the light output. Anyhow, some pictures are attached and they really don't do it justice. Any questions, please ask.
    Ps. Ignore the dirty car. Haven't had a chance to clean!
    2013 Touareg V8TDi - Black, LED Interior Mods, LED Projector "VW" Door Courtesy Lights, 20" VW Mountain Rims with A/T Tyres, Pioneer SX Roof Platform with some 4x4 accessories and a whole lotta torque
    Thanks for the detailed instructions and the links - I just picked up an r36 recently and this is a great help as I undergo a similar exercise on my car
    NickZ
    Former ride: MY07 Black Polo GTI
    Current: MY09 Blue Passat R36 Wagon
      No problems. Next installment will be rear number plate LED's. Will be interesting for that one
        got any pics on how to do it? like where you push the mirror and where the screws are to be removed from?
          Have you looked at my article. I think it is pretty detailed and there are pics!!
            Hey snerlo let me know when you do the tail lights. I need to do mine as well. We can do them together. 2 heads are better than one. Just ask all our Tasmanian Brethren.
            Rising Blue MY10 Passat R36
            BLACK '97 Mk3 GL 2.0L
            White '82 MK1 Cabrio 1.8L
            Vice-President - VWDCQ (VW Drivers Club of Queenland inc)
              Check out my new thread mate
                Thanks for the guide Snerlo. Makes it a lot easier.
                Puddle lights arrived today and were easy to install. Only problem was one of the wires had come loose so just re-soldered it.
                Looks great.
                2010 Passat R36 - Icelandic Grey / BT / MDI / Power Tailgate / RVC / Cargo Management System / 19" Lugano Wheels
                2005 35th Anniversary 350Z - Ultra Yellow / Stillen True Dual Exhaust / Motordyne MREV 2 and Plenum Spacer
                  Don't know if anyone has tried yet.... Just wondering if this was to be done on a B7 Passat, would the whole mirror need to be removed? I've had a look at mine, looks like surgery!
                  MY11 B7 Passat 125TDi Highline
                  Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
                    I have the same question. Also, is there a complication as the car has the lane assist option? Thanks for the good description above but our B7 looks different.
                      Sorry guys, I can't comment on the B7's as I haven't looked at one before. I'm sure someone has done it somewhere in the world
                        Thanks, Snerlo. The US B7 has puddle lights from the doors. My guess is it is where Aust has the reflector insert in the door. The reflector part also curves below as well as on the inner face of the door. It would take a lot of effort to get these up and running. So it will be the mirror doors if I can discover how to do them.
                          Bold-Sport.com :: Door Warning Lights Housing
                            I got ya now. Sorry to say, but that is totally useless if you ask me because you would walk into the puddle to open the door rather than trying to avoid it in the first place which is what the puddle lights are for. Obviously once you open the door and the light shines down, then you can see where you are standing but that all just seems a little bizarre to me!! Weird!
                              Those aren't puddle lights - they are just what they are called - door warning lights. Presumably to make it obvious to passing cars, bikes or pedestrians that the door is open. My old Mazda 626 Coupe in 1985 had them
                              The B7 puddle lights are in the mirror - but located in the outboard "hinged" part and seemingly more integrated then the B6. They also look to be a different size/shape too.Click image for larger version
ID:	1814695Click image for larger version
                              2017 206 TSi R-Line
