Evening all,
Have spent hours looking at the various posts, so apologies if this is duplicated. I have a 2014 high line with factory audio and an aftermarket sub, and optical sensors and auto park. My RNS510 unit is slowly failing - first the startup screen shifted left about 5 years ago, then a couple of years ago the colours all changed. Over the last 3 months it’s been booting slowly or not at all - sometimes it works straight away, sometimes kicks in after a hour or so and then sometimes not at all - just gets stuck in boot screen, logo then reboots.
Looking at replacement options. I’ve seen the upgrade thread to latest VW but that’s pushing the budget and can’t spend the time to sort it. Looking at an aftermarket head unit plus surround plus cables for around 800-1000 for pioneer or alpine with wireless apple CarPlay.
I’ve seen both alpine and pioneer make an adapter to the high camera (ie the one with the turning reversing guides) but these are about 250-300.
I don’t really care about this turning functionality. Can I get an adapter (or solder / connect) to hook the current cam up to the new unit much cheaper without needing this adapter? Or am I better off running wires to a new aftermarket cam? Only other info is that occasionally the current camera has all horizontal lines and image flicker - appears to be intermittent - would this be a sign that maybe the current cam and wiring is needing to be replaced anyway?
Appreciate any replies. Once I solve this one I might have a crack at the rear wiper water spray - which is low if any pressure and seems to correlate with drips from the drivers seatbelt area - suspect this hose leaks…
Tom
Tom
