Less cooling on left side AC vents after upgrading climatronic
  • Less cooling on left side AC vents after upgrading climatronic
    Hi,
    I have Passat B7 and I upgraded my climatronic from 5K0907044FH to 3AA907044BQ.
    Did basic settings and everything is working fine without any error (except Air Quality sensor) but I observed cooling on left is less compared to right side even when temperature on both side is same.
    Both side temperature set to 21.5 and temperature on right vent is 20.7 and left vent is 25.7. If reduce I temp of left side to 17 then the temp on left vent goes to 20.
    I switched back to old climatronic and everything is working fine.
    Below are screenshots of advanced measuring blocks of both panel.
    Old Panel
    New Panel
    Solved by coding 0014002003 in climatronic
