Hi!
I've done a fair bit of reading up on this and have some suspicions of what's going on, but I figure I'll ask my own questions anyway...
Here's the situation; we've had the car for about a year and it was all fine, but then I started noticing that when I put my foot down to overtake things would stutter a bit, like it was misfiring or not getting enough fuel. Sort of like when the points are going on an old dizzy car. It seems to be getting worse. We were in the hills around Mt Bawbaw a little while ago and it started doing it and then the glow plug light came on and the computer was saying get it to a mechanic, so we changed our plans and slowly drove it 200kms home and left it at the (VAG specialist) mechanic. He found a fault with the exhaust gas temp probe so replaced it, but it hasn't fixed the problem. It happened again at the top of Mt Buller a few weeks back; this time it didn't seem to want to shift out of 2nd but it would rev high. It didn't last long, and once we'd unpacked the car and I started it up again everything seemed fine. I dropped it at the mechanic again and he had it for a few days. He recognises there's a problem but he's not sure what it is. There's no codes. He didn't charge me for the investigations he did.
I can elicit the symptom easily now. Driving around with a light touch on the pedal everything is fine, but if I put my boot down a bit, it stutters. I'm not brave enough to do this to the point of getting the engine fault light to come on. Reading around, it could be a few things, but I'm actually thinking it might be a DSG thing. It's coming up to 120k and the DSG was last looked at at about 60k. I've read that if the oil is old/low it might get all muddled up or something.
As an extra bit of information that may or may not be relevant; I was parked with the car facing uphill a while back and it wouldn't start after being left overnight with a less than half full tank. Rolling back to level, it started fine. I haven't had a chance to try to make this happen again.
I'm thinking I'll book it in for a DSG service, and I need to replace the AC compressor too. Do any of you have any other obvious thoughts? It'd be totally cool if someone said "Oh yeah, that's obviously such-and-such (and it's really cheap to fix)"
Ta
Ta
