Hey Guys/Gals,
I've got a few questions that I can't find answers to so I'm throwing up a new thread. Before I get too far into it, I'm just going to see if this one appears as I went to a bit of trouble writing a thread just like this one earlier and for some reason it needed moderators approval and has not appeared.
EDIT-all's good this time so here goes:
I bought a 2010 R36 (110,000km) cheap as it had a check engine light for camshaft/crankshaft sensor synchronisation issue. Clearing the code only worked for about 30 seconds. It started well, drove great but had about 2 seconds of valvetrain noise on startup and a slightly choppy idle.
A bit of reading suggested it may be a timing chain/tensioner/guide issue. Warm engine compression test gave readings of 210, 200, 210, 200, 190, 190 (psi) so the engine itself seemed pretty healthy and drove that way too. I started disassembly and once I got the cam cover off I noticed that the locking slot on the intake cam was not sitting horizontal as it should when all the timing marks on the cam sprockets were in the correct disassembly/reassembly position. I retrospect, this clearly indicates that the cam adjuster had was not 100% but hey-I'm experienced in Subarus and Fords so I thought it best to leave this one to the experts.
I booked the car in to have the timing chains/tensioners/guides replaced at a nearby VW workshop. I reassembled the car and it drove beautifully into town to drop off at the workshop. I left it with them and headed back a week later to pick the car up. I was told the car refused to turn over initially and that the technician who had done the work had then "re-timed" it and tried again. This time it would not start and compression testing showed results of 40-50 psi on all cylinders. The workshop contends that the issue is caused by the sudden complete failure of the cam adjuster on the intake cam. I've seen this with my own eyes-the intake cam can be moved from retard stop to advance stop (about 20 degrees I guess) without putting any force through the sprocket onto the timing chain. I expressed my disbelief that a an issue that had not progressed in the last 9 months of ownership would suddenly cause a catastrophic failure while the car is in the workshop.
Questions:
1. How common is a sudden complete failure of a cam adjuster that causes an engine to become inoperable?
2. Would a failed cam adjuster allow the cam enough range of movement between the advance and retard stops to cause contact between the valves and pistons?
3. Would a mis-timed cam timing causing piston to valve contact be enough to further damage the intake cam adjuster?
Sorry for the long-winded thread and if you've read this far, I certainly appreciate it. I love the car, I love mucking about with cars and I hope to get the car back and contribute to this part of the forum.
Thanks,
Ben
Questions:
Thanks,
Ben
