Hi all,
Have 2011 Passat TDI 125kw. Has about 250K on clock.
A few times (probably four or five now) over the last six months it has started, run for a moment or two and then quit, while flashing the coil lights.
Taking the key out and restarting makes the coil lights go away.
Used a scanner tonight - found no stored fault codes.
Some research has suggested an anti-shudder value might be the issue, although I'm unsure if they are still fitted on these cars (most of the stuff I saw was for slightly earlier generation).
Appreciate any and all advice - thank you.
