I've got the big panoramic sunroof and when its retracting it makes a loud rubbing noise. Totally embarrassing when I'm showing off my awesome Passat to friends. Does anyone know how this can be fixed? I tried some silicon lubricant but it made little difference, its hard to know exactly which bit is causing the noise. I assume this is a fairly common issue?
Noisy squeaky sunroof
It's till giving me hassles. I believe there the rails need lubrication and there was a PDF guide on how to get into the rails, what type of lube to use and where to apply it, but it's not active anymore (404 Not Found)
Anyone got a copy of this PDF?
Hi all
I am also after guidance on the pano roof. I managed to get it quiet with some aerosol dry lube... but would rather do it the right way with the right stuff.
It is not as obvious as other sunroofs . You can’t see what runs on where from the outside.... anyone got tips?
Sent from my iPhone using Tapatalksigpic
Having a Gap Year!!!!
what next?... what next?
