VCDC scan HELP HELP HELP
  • VCDC scan HELP HELP HELP
    What software to use to scan vw passat? I have that blue vag-com cable, and vcdc installed on my laptop and when i try to set up port in options shows error on all 4 ports.
    Sent from my SM-G925I using Tapatalk
    Blue vag-com cable? Is it a genuine one? Which cable version are you using?
    Sent from my Nexus 9 using Tapatalk
    Using Tapatalk
      Its one of ebay... worked before with my audi,but now wont for some reason.... 901 vag-com or something like that...
        Sorry can't help you when it comes to using a non genuine cable. This is the problem with using cheap knock offs. Sometimes they work some times they don't.
        Perhaps there is someone local to you with a genuine cable that can help you out.
        Using Tapatalk
          PM me a number and an address. If I have time over the weekend I'll call and arrange to scan it if I can. I am here until Monday morning.
            Messaged u my number....
              Will depend what year the car is. The blue KKL cables are good for pre CAN.
              I just saw you are B5.5 Cable should work. Need correct software.
              I splashed out the $90 for the Vag-Com software because it does stuff easier than some of the backdoor stuff.
