Passat b5.5 1.8t limp mode
  • Passat b5.5 1.8t limp mode
    Hi guys,today my passat stared to playing up with transmition... its automatic,was driving home,and oil light came on,abs light on,airbag as well... and its not changing gears... everything was fine til today.. car has done 177kms. What could it be? Is it in limp mode? Or? It was stuck on D light on little lcd in dash.... wont change as i move through gears... any help what could cause this would be grat..
    Sent from my SM-G925I using Tapatalk
    Vcds scan required.
      What could cause this?
        Scan it first.
        Also, does it have a sunroof, and does the car smell damp inside?
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
          Originally posted by Umai Naa!! View Post
          Scan it first.
          No sunroof.... wasnt any smells in side at all. I tried to disconnect battery. .. didnt fix limp mode. Also while i was driveing,rpms were stuck at 2000 and speedo at 5o km/h. Even when i swich off ignition ant took key out speedo and rpms didnt move... still sitting on last speed i was driveing... after i disconnect battery they went down to 0 again..
            Yeah, get it scanned and diagnosed. We're all just taking stabs in the dark here.
            '01 Beetle 2.0
              What software to scan with? I have that blue vag-com cable,and vcdc installed on laptop but when i try to set port usb on all 4 says error....
