hello everyone my problem is I wanted to check cigarette lighter fuse but of course the vw manual fuse box is different to what's actually in the car so stupidly I removed all fuses on the left side while ignition was on and now I have the orange parking light flashing and a beep on the dash,i have disconnected the battery to try and reset but did not work ,checked on vcds and cant pinpoint which fault it is .can anyone help me out??
oh and my car is 08 Passat b6
flashing parklight light on dash
Easiest to post a picture of the particular symbol mate. That will make it easier to pinpoint for you.2013 Touareg V8TDi - Black, LED Interior Mods, LED Projector "VW" Door Courtesy Lights, 20" VW Mountain Rims with A/T Tyres, Pioneer SX Roof Platform with some 4x4 accessories and a whole lotta torque
ok finally fixed it all I did was just this test - Lateral/Longitudinal Acceleration & Yaw Rate Sensor (G200/G202/G251) Prerequisites:
- System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 2, 3 and 4 - their value has to be between -1.5 and +1.5 m/s² or °/s.
[Done, Go Back]
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 061
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
Group 004
[Go!]
[Done, Go Back]
[Close Controller, Go Back - 06]
and that's it mil light has gone and auto hold working again ,hope this helps other people if they get this annoying fault.
