Hi All,
So in ~17 years car ownership I have had the opportunity to jump start many a car (mainly thanks to my affection for old cars, that invariably spend more time on stands than they do the road). In that time I have never had an issue jumping car (new, old or inbetween).. so I am rather embarrassed to say that I am having huge issues with my MY14.5 Passat (118TSI) and getting it going.
Long story short, I left the keys in the car over night, which has resulted in a drained battery (confirmed by clicking when trying to turn the engine over).. No big issue I thought, I grabbed one of the other cars, did the usual jumper lead setup (+ to +, - to chassis), this immediately gave the Passat enough power to boot up all the electronics etc.. however when I tried to crank the car over, I get nothing (i.e. not even the clicking sound of the starter motor solenoid trying to engage).
Thinking I had a bad connection, I removed the jumper leads and started again, same result.. I get power but no ignition. Once I removed the jumper leads entirely, I tried to start the car again, same result, electrical power (low) but absolutely no sign of ignition. Paying a little closer attention, I note that the car is through a couple of codes (ESC Disabled amongst others) and there is a flashing spanner on the MFD.
So, my embarrassing question is.. WTF have I done? I am not a VW knowledge base, and dont have a VAG tool, is this issue simply a result of the battery pushing low voltage and the car through codes as a result.. I'm assuming I cant clear the codes through an OBD scanner? I will trickle charge the battery tonight, so that will hopefully address the local power issues.. any guidance you lot can offer would be VERY welcome!
Thanks in advance
Chris
Thanks in advance
Chris
