Passat wagon b5.5 suspension question
  • Passat wagon b5.5 suspension question
    Bought passat wagon b5.5 (finally,always wanted one) automatic 1.8T . i wona lowered the car a bit... coilovers or just low springs.... any suggestion would be great.. and where to get them from? cheers
    Sent from my SM-G920I using Tapatalk
    I did a lot of research into upgraded suspension for my B6 Passat. I don't think the cost of coilovers can be justified in many cases for normal road use. Good ones are fairly expensive. If you want to lower your car a bit (say 30mm) with an uprated spring rate, I would suggest Eibach springs. If you want to lower even more (40mm), then I suggest H&R. My own personal opinion is H&R are too low due to kerb/ground clearance issues and that Eibach are a better choice.
    I found that you can buy them from suppliers in Germany via eBay for nearly half the price in Australia as long as you have done your research and are absolutely certain you are ordering the correct part no.
    I wouldn't change springs without changing shocks as well. The uprated spring rate should be matched to a similarly uprated shock. I suggest Koni yellows which might be easier to buy in Australia.
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
