Highline Reversing Camera for R36 wagon - Is it worth it?
  • #16
    Originally posted by prn31 View Post
    On a related subject, my camera occasionally doesn't come on when I select reverse and at other times the camera comes on for a few seconds and then it goes to the OPS screen. Any idea what could be going on?
    Mine was a dealer fit not an original VW part and it comes on when I select reverse, but if I select drive and then reverse again (ie. three point turn) the camera won't come back on again unless I hit the parking sensor button to turn OPS off and then go drive reverse again. It seems like OPS overrides the camera. It also throws codes in VCDS but it all works fine other than that so I have to either ignore the codes or remove the camera. I put up with the codes.
    If I were the original owner I'd have made the dealer fix the install or undo/refund but as I'm the second owner I deal with it.
