A big thanks to Michael Weber at Performance & Prestige in Brisbane who fixed a failed Haldex pump on my R36 wagon. You have no idea how much work the Haldex does until it stops working! When mine went suddenly 2WD I figured on a huge bill for a new Haldex unit. But P&P simply stripped down the pump, cleaned, resealed, re-lubed and I was back on the road in full working order for less than $200. Outstanding! Apparently they've 'done' a few of these, so if yours plays up I highly recommend giving them a call...
Failed Haldex pump repaired - less than $200
Whats the symptom of a failed Haldex pump?2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
Give it a bootful at the lights, and the front wheels spin like crazy, Traction control lights fires up etc. Doesn't happen with a working Haldex. Thence onwards to VAGS diagnostics indicates failed pump. But it becomes really obvious as soon as it happens as the whole dynamics of the car change (for the worse). I don't think it could ever go undetected!MY 2010.5 R36 wagon - Biscay Blue - power tailgate - 1800kg tower.
MY 2006 Mk5 GTI - reflex silver - leather - DSG - sunroof - bixenons
OK, thanks, will pay attention to this!2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
Thanks for the tip mate. Appreciate it.2013 Touareg V8TDi - Black, LED Interior Mods, LED Projector "VW" Door Courtesy Lights, 20" VW Mountain Rims with A/T Tyres, Pioneer SX Roof Platform with some 4x4 accessories and a whole lotta torque
FYI this is what I also went through but blamed my tyres before diagnosing the fault. No pump means you're not pressurising to drive the clutch which means your rear wheels are permanently disengaged, which obviously means no AWD so less grip and thus the issues the OP describes. If you baby the car it will actually be hard to notice mostly, if you're an enthusiastic driver you will notice something is off pretty quickly.
My pump is probably not repairable as the death of mine was an electrical fault, you can also just replace the pump with new, it's a $700 part or closer to $600 if you know someone in the parts department. For my car the part number was 0AY598549A but best check with VW as yours may be different.
