R36 wagon tail light problem
  • R36 wagon tail light problem
    Hi all,
    I noticed the other day that th RH rear tail light chrome disc has come loose. You can see the difference between the two lights. I thought it would be worth asking if this is repairable at all before I waste hours removing the light only to find its a sealed unit with no access to this area. If it is repairable does anyone have a guide to remove?
    Thanks. Scott.
Name:	Rear Lights 2.JPG
Name:	Rear Lights 1.JPG
    is the car still under warranty?
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
      check the photos here
      403 Forbidden
      looks like you need a whole light replacement
      2018 BMW 125i M Sport |AlpineWhite|719M JetBlack|BlackLeather |ComfortPackage|Sunroof|WirelessCharging
      2010 MY10 R36 Wagon | Biscay Blue | Power Tailgate | RNS510 | MDI | RVC | 51,000 km |Garage Open Button | Dead Pedal Mod | OE Fit DRL | VCDS | Sprint Booster | H&R Rear Sway Bar | Alcantara Steering Wheel | Dual Reverse Light | 19" Bentley Wheels (BBS Forged Split) | Michelin PS 4S
      2005 MY05 AH Astra HatchBlack | Facelifted SRi Looking | OpeliZed | Whiteline RSB | Eibach ProKit
        removal guide here
        How to remove the tail light on a passat B6 / 3C | omfg.dk
          No. Not under warranty. 2008 model unfortunately.
            Thanks for that. Wow. That looks easy to remove. Only one screw and some clips. I was expecting a heap of screws on the inside like other cars I've owned.
