I`m trying to add OPS to my b6, I have purchase the following -
VW Passat B6 Optical Parking System OPS 56D 919 475 A-in Parking Assistance from Automobiles & Motorcycles on Aliexpress.com
Instructions say-
The new PDC controller doesn't connect to the comfort CANBUS network but instead the drive CANBUS network. If you have bi-xenons installed the controller for this can be used to connect into the CANBUS network otherwise you need to use the CAN gateway.
Remove the three connectors from the PDC unit (located near the drivers side of the car behind the rear wheel inside)
The brown plug (T16) with a orange/brown cable on pin 7 and orange/purple cable on pin 14 needs to have the outer housing removed by lifting the clip on the end and sliding the black connector out. Pin 7 and 14 are connected to the Comfort CANBUS network.
Remove pins 3, 7 and 14 as these are no longer required and ensure they are individually protected again short circuit with heatshrink tubing or electrical tape.
Connect the can bus cabling.
CAN High goes to T16 Pin 6
CAN Low goes to T16 Pin 15
Connecting the CANBUS network.
On the bi-xenon connector (T-26) Pin 2 is CAN High (orange/purple) and Pin 3 is CAN Low (orange/brown)
On the CAN gate connector (T-20e) Pin 16 is CAN High and Pin 6 is CAN Low.
Remove the connector (blue) from the CAN Gateway and remove pin 2.
The old PDC was at address 76 and the new one OPS is address 10.
Now I`m very unfirmilua with the passats wiring, I have no idea where the bi-xenon head light connector is. Was hoping someone to interperate the instructions for me and translate it to something I can understand. Yes I do have bi-xenons.
Instructions say-
