Passat genuine (dealer fitted) Bluetooth
  • Passat genuine (dealer fitted) Bluetooth
    Has anyone here got a dealer fitted bluetooth?
    I would like to know and if possible see pics of where the mic is mounted..
    I drove a s/h car the other day and the mic was mounted with double sided tape between the steering wheel and instrument cluster... lookled butt ugly TBH
    MY12 Volvo V60 T5 Tekink in Ice White
    MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
    Anyone....
    Does noone here have the VW fitted bluetooth in their Passat?
      Hi all this is my first post. I have recently purchased a new passat wagon and got the factory blue tooth option. I must say that the quality of the blue tooth is pretty average and the worst part of the whole car IMO as the rest of the car is awesome.
      As for the fitting, the mike has a little black bracket next to the stereo up near the drivers left leg. The photos are taken with my phone so they are not the best quality.
      http://chuckey.gallery.netspace.net.au/album03/DSC00296
      http://chuckey.gallery.netspace.net.au/album03/DSC00297
        Chuckey thanks for posting the pics... you have alayed my concerns about the fitting of the mic...
        imike thanks also for your PM
        only 1 more sleep till I get my new baby...
          Which dealer fitted the bluetooth kit, they need to learn the correct method of installation. The mic is to far away and you will have annoying feedback.
          1st place Mk3 Standard 08
            The dealer that installed my blue tooth kit was Camberwell Volkswagen in Melbourne. I find that if I turn up the volume too much then the person on the other end gets a bad echo. People also comment that the quality of my voice is not very good.
            Any tips on where the mike should be placed 95vr6.
              Usually the mic is mounted on the RH pillar between the windscreen and RH door.... although the wifes Beema has it centre of windscreen above the rear view mirror. Both locations seem OK in my experience.
              Guess I'll find out tomorrrow where mine is located...
                I install mostly Nokia bluetooth kits for coparate customers, the A pillar or just above the centre mirror are the best spots to place mic. Do you have the audio coming through the factory speakers. I find if the Rx audio is to loud it will cause feedback. I would request the dealer to relocate mic to the above locations.
                  I agree re the location and will get it moved... The audio is via the stereo and I have found in the wifes Beema that when she has the audio up too loud the audio clips and cuts out due to feedback. Your comment about the Rx audio being too high seems valid.
                  I got noticable improvement by setting the phone audio to 100% LH front speaker which is the most shielded speaker relative to the mic. Perhaps since the mic is the better part of half a meter from my head the AGC on the mic makes it too sensitive... ?? relocating to the A-pillar seems to make sense.
                  I note that there is a series of grill holes in the overhead console that has the lights in it... perhaps in there would be good too? I see in the manual the euro models seem to have a cradle option as well... perhaps it is a fully intergrated factory fit option there?
                    The grills you are talking about is where the factory mic is located in the old W8 passat aswell. See if they can mount it behind this panel for factory fit, if they dont damage the panel on removal.
                      Now I'll have to investigate it further... If VW can/wont do it I'll go to my local installer whom I have tyrusted with my cars before and see what he can recommend/do...
                      I'll probably get a second mic and test it in a couple locations before I get it installed though... I assume the mic is a standard hi gain capacitive unit like all the others??
                        Cruising around the web I have found some interesting stuff on VW bluetooth...
                        This appears to be the brand of units fitted by VW in OZ..
                        Techaudio
                        And here are some interesting links...
                        This one shows the mic installed in o/head console..
                        Jetta Bluetooth install
                        Adaptors and interface for VW
                        VW bluetooth for sale
                          For the genuine bluetooth kit, does it come with a key pad which can be hided in the top centre console there? Or it is a different one
                          Delivered 9/6/08 : MY 08 (Mar 08 Build) Passat 125kw
                          Sunroof|Leather+Mem Seat|Bi-Xenon|RNS510|Alarm|Fog Lights.
                            The dealer fitted unit has no controls or keypad... The audio volume is controlled via the stereo or steering wheel buttons while in a call, and the answer/hangup/voice dial (if supported by your phone) is controlled via the buttins on the steering wheel.
                            Now I have the echo issue sorted I have enabled the voice dial on my phone.... works a treat I must say. I have a completely different view of the system now.
                            Phonebook access and caller display via the MFD would be good but not essential IMO
                              I had mine also fitted at Camberwell Volkswagen. When i asked where the microphone would be mounted they said anywhere as long as the cable would be long enough. I had it mounted at the A pilar.
                              The sound i get through the factory speakers is good, however the caller hears a lot of background noise and the sound quality even with engine off is not very good. No echo though.
                              The old hardwired Nokia kits provided much better sound quality.
                              I wonder if sound quality would be better if the microphone was installed closer to the driver (in the top centre console perhaps?)
