Hi all
Does anyone have any direct experience with replacing the mechanical water pump on an R36 engine with and electric version, such as these? Electric Water Pumps
In some instances they claimed that 10kw can be gained from changing the mechanical water pump to an electric water pump...! Plus, the cooling benefits are considerable too.
At around $450.00 for the full kit, its not a bad way to gain 10kw! And the argument they pose for the much more stabilised cooling carries considerable weight.
But, will it work on an R36 with all the computer controlled functions etc? Am I correct in thinking that the R36, or most of the late model VW's use the CANBUS system? Evidently, this MAY be a problem with electric water pumps as the CANBUS system doesn't like such innovations like electric water pumps.
Can anyone advise and details on these issues?
Rgd's
Andrew
Rgd's
Andrew
