Over the weekend the Tyre pressure warning light lit up on my 2007 TDI Passat sedan. According to the manual it means "Tire pressure low or system failure". As I my vehicle doesn't have tyre pressure monitoring (at least I don't think so), what does this warning mean? I swapped the spare onto the vehicle the day before the light came on, as I was repairing a scratch in the alloys. After the light came on I checked tyre pressures, and all fine. Any ideas. The symbol looks like a flat tyre with an exlamation mark (!) in the middle. Thanks in anticipation. Daniel
2007 TDI Passat Warning Light
Originally posted by dc08 View PostOver the weekend the Tyre pressure warning light lit up on my 2007 TDI Passat sedan. According to the manual it means "Tire pressure low or system failure". As I my vehicle doesn't have tyre pressure monitoring (at least I don't think so), what does this warning mean? I swapped the spare onto the vehicle the day before the light came on, as I was repairing a scratch in the alloys. After the light came on I checked tyre pressures, and all fine. Any ideas. The symbol looks like a flat tyre with an exlamation mark (!) in the middle. Thanks in anticipation. Daniel
It sounds like it has the system that works with the ABS system and measures the diameter etc of the tyre. This is standard on some later models and when you change a tyre it has to learn the new one Read the manual and it will tell you about it.
Does it have a button which looks like a cross section of a tyre with an exclamation mark down by the shifter If so thats what it has If not Cant help you.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Yep, it is the button with a cross section of a tyre with an exclamation mark. It is displayed on the tachometer, not down by the shifter, but I reckon you may be right, it is measuring the diameter of the tyre and needs to learn the new one. I swapped the wheelthe night before, then the warning light came on half way through a 50 km journey the next day. I'll read the manual more closely and see what it says. Thanks again!Originally posted by Hillbilly View PostIt sounds like it has the system that works with the ABS system and measures the diameter etc of the tyre. This is standard on some later models and when you change a tyre it has to learn the new one Read the manual and it will tell you about it.
Yep, just went and checked. There is a button near the shifter. Hold it in and the light on the dash goes out. Sorry, i'll check the owners manual more thoroughly next time.Originally posted by Umai Naa!! View PostShould be a button with the same symbol on it near the gear lever. Hold it in until the light blinks and extinguishes.
