Hey guys can anyone help me, I was driving my car the other day sitting on 110 cruise control on started to go up a hill and my engine light started to flash so I turnt crusie control off and actually accelelrated up the hill and it stopped flashing. Anyone know what could be I was thinking not enough pressure? I think i do have a slight hole in my exhaust so might be exhaust leak need help anyone. Cheers
HELP!!! Flashing Engine Light
You need the fault code to go further. Google exactly what the scanner said. VCDS being better than a generic one for the information it gives you. There is a basic settings for that flap motor. Not a guaranteed fix though.
It ok found it cheers just typed it in google.
000771 Misfire detected cylinder 3
000772 Misfire detected cylinder 4
008213 Intake Manifold Flap Position Sensor.
Since i have gone got this done and they cleared the errors hasnt come back but mind u after they did this my battery died so $224 to install a new one wasnt happy.
18447/P2015/008213 - Ross-Tech Wiki
Definitely perform the basic settings first and go from there.
see this topic
VWVortex.com - CEL Intake Manifold Flap Position Sensor
someone else reported the same combo: intake manifold failure (flapper) causes (?) cylinder misfire.
thezoner32 had this error on his GTI and I carried out basic settings and it has stayed away.Originally posted by passat08 View PostHas anyone had this fixed before? Trying work out if need new intake manifold or new other thing
