I'm not too happy with the auto tailgate. Two things. One is interfering with it by hand. The other is the slam it does over the last 8 inches.
First, if you lift it open by hand as you might do if you didn't know it is automatic, it actually reverses and slams shut again as if in irritation. So you must treat it carefully - use the key, or pop the handle, stand back. Wait.
Second, when closing, it slams shut over the last part of its travel and I wince every time my dog is in the back: if he were to try to dart out at the last second or get a paw caught it'd be tragic. If it allowed manual operation or had a soft close, all would be fine. Given it must go from fully open to slam over some seconds, there is quite an interval for the pet to make his fatal mistake it isn't like you bring it down, look through the glass to make sure fido didn't freak, then close it.
Third, and this I'll get attended to under warranty, sometimes it doesn't open, the motor engages and it pops a bit but then just cancels. This usually after the car has been sitting for a while. Like it can't overcome the initial resistance.
One last thing that is odd, from the drivers position you can't close the gate, only open it? So you must get out, walk around, and press the red button.
All these annoyances are balanced by the convenience of popping the gate upon approach to the car, or pushing the button and walking away. But given the above issues I'm thinking a light smoothly operating manual gate is overall easier and indeed faster and safer (for pets).
If you're thinking of ticking this option, the design isn't great, IMO.
PS: mercedes auto tailgate works right, you can move it manually. It soft closes, you can close it from the the drivers seat, and it has the height-set button right there. I wish VW had compared it.
