Ok in case anyone has a new passat and is hesitating. My RNS510 came with V5 map data, and it gets a lot of speeds wrong, the time to destination estimate is useless, etc etc.
The dealer, Barloworld, bless their tight fisted hearts gave me a V4 map DVD when i asked why one was not in the car. If I was better informed I'd have thrown it back and demanded the V5 DVD but eh what can you do.
Online elsewhere in vwwatercooled I found the Feb V6 australian map image hosted by google drive, which fits onto a burned CD. This update process took about 15 minutes if you do it in a quiet car you can hear the disk and the HDD alternately grinding away. If you get worried that the RNS510 will shut itself off to preserve battery you can start the car while it is still going. If you try to Eject the disk during the process - because maps etc still work while it is running, so it is confusing as to what is going on - it'll tell you it is still copying data and ask if you want to be notified when it is done. Obviously pick Notify, when it is done it ejects the disk.
Second, I wanted the "secret" menu enabled (which has audio "Loudness" on by default), and video in motion to amuse the kids when driving long distances on private property. I used the Berto89 recode video in motion ISO image. At first I failed because I didn't clearly notice the correct way of doing it, which is this:
1. keys out
2. turn on RNS510 eg to radio
3. three finger salute: Setup + Eject + the button next to Eject .. this isn't the three fingered reboot, it is "prep for possible firmware downgrade" option. The instant you do this the radio blacks out and will attempt to power up
4. Insert the VIM burned CD (the data on the CD is really tiny - just a script to set two flash location values, whose addresses do not seem to change with each new version of RNS510 firmware)
5. The unit will boot off this CD and then a screen will come up with some details and an OK button
6. Press OK and it runs, almost instantly, as nothing need be read or written to HDD or whatever, just flash
7. Eject the disk.
8. That's it..
You can tell it worked even without a DVD if you hold down SETUP for 20 seconds and the first "secret menu" switches to the second more extensive "secret menu" at the 20 second mark. That means VIM got enabled as well.
1. keys out
7. Eject the disk.
8. That's it..
