A Milford Cargo Barrier is designed to stop an object as heavy as 60kg from penetrating it.
Hence its 19th Century looks. Its Utilitarian not beautiful
Also you could fit one yourself if you dont mind cutting holes through the roof lining and the floor
That is presuming they install similar to what I had in a Landcruiser.
It involved drilling 22mm holes just above the doors in the rear Or the rear window for a minimum use area. Two plastic plates fit over those holes with a metal plate behind to bolt into
You then had to drill the floor to install plates that the locating arms bolted into.
I wouldnt like to do that in a Passat I used an expandable unit that was a dog barrier in a Nissan for a while and it worked OK to hold luggage back. Didnt require any holes
