R36 needle sweep
  • R36 needle sweep
    Hi all do you know if this feature is available? My ride is 2008 avant with the red screen not the later model white. If it is available does it require vag com coding?
    I have the same year model, does not have the option in VCDC. I believe it is only available on later models
      What's needle sweep?
      Biscay Blue 2009 R36 Wagon
      RNS510 w/ Reverse Camera | Sunroof | Auto Tail Gate | 30,000kms
      VCDS Changes: Rain Sense Auto Close | Tear Drop Wipe | Lock/Unlock Beep
      Checkout my thread
        When you start the car up the needles sweep up from the bottom left all the way to the right hand side (also called needle dance).
        Pointless feature but it gets a laugh.
        I thought it was only available on white MFD cars.
          Thanks everyone
            Pointless feature but entertaining for many I would think. Easily amused are us males!
              The feature is called staging and only available on certain clusters, not limited to whitedot or reddot mfd either as it is available on my premium colour mfd.
                Figured as much, thanks fir the confirmation!
                And yeah, sounds like something I'd love to have activated on mine too - so wanky lol
                Checkout my thread
                  Hey booba How do we check if the staging is available?
                    connect vcds and try to enable it.
                      If only I had the rosstech cable rather than the cheapy Ebay one then I might actually be able to do something other than scan for fault codes!
                        get the rosstech one.. very handy for more than just fault codes.
                          Just tried on mine and it's a no go...
                          In VCDS go to Control Modules > Instruments > Adaptation > Staging
                          Mine said 'Channel not available'
                          Checkout my thread
                            White mfd my2010 still no go.
                            Read you have to be 2011+
                            2009 Volkswagen R36 Wagon
                            1968 Audi F103 75L Coupe
                            1966 Volkswagen Beetle Deluxe
                              Shattered.
                              Can always do it the old fashion way.. revving that bad boy out, hah.
                              Biscay Blue Volkswagen R36 MY09
