Gday all...
I recently bought a VW b5.5 Passat v5 have been having issues with the EPC and ESP light coming on, and the car running like a pig (low/fluctuating revs). I reset the computer and it runs like new, sometimes for a week, other times for a day, other times for a few hundred metres.
I had a local mech run a Diagnostic for me (, and i'm more confused than ever, 10 FAULTS. Can one issue trigger the others and if so which one is the likely cause so that I can get my family mech/dealer to fix it (as the car is still under statuatory warranty).
Can anyone recommend what is the likely cause of all these problems?
Cheers, Dom.
FAULT CODES
16500 - Engine Coolant Temp. Sensor (G62)
P00115 - 35-00 - Implausible Signal
17887 - Brake Boost Vacuum System
P1479 - 35-10 - Mechanical Failure - Intermittent
17550 - Load Calculation Cross Check
P1142 - 35-10 - Malfunction - Intermittent
17953 - Throttle Valve Controller
P1545 - 35-10 - Malfunction - Intermittent
17967 - Throttle Body ( J338 )
P1559 - 35-10 - Adaptation Not Started
17987 - Throttle Actuator ( J338 )
P1579 - 35-10 - Adaptation Not Started
16487 - Mass Flow Air Sensor (G70)
P0103 - 35-00 - Signal too High
17976 - Throttle Actuator ( J338 )
P1568 - 35-10 - Mechanical Failure - Intermittent
16891 - idle Control System RPM
P0507 - 35-00 - Higher than Expected
Cheers, Dom.
FAULT CODES
