Hey guys..
My Reverse Light has sporadically given up the Ghost..
At first I thought it was just the bulb...
Nope bulb is sweet
VCDS is registering that there is a Electrical problem with the Circuit.
I have pulled out the Multimeter and Checked for Continuity with the Ground.. All seems to be ok..
There seems to be no positive feed coming thru at all... all other lights are working Faultlessly...
Anyone got a pinout diagram of the CECM...?
I have even swapped can gateways to try and eliminate the possibility of it being faulty..
Happy to run an entire new wire to the reverse light if that will fix it just would like a CECM Pinout to save time finding the relevant pins on the CECM...
Nope bulb is sweet
