I'm tired of only getting 30 k kms on a set of tyres. This has been the case with the original RE050As and the subsequent RE001 Potenzas. Any suggestions?
New tyres for TDI wagon
Run higher pressures than the soft-as recommendations... Particularly if you're running consistent high speeds or heavy loads.
As for tyre brands, I've had the original Contis and now on Michelins.. 55,000km on the Contis, and had about 3mm tread left when replaced. Done about 40,000km on the Michelins, haven't even thought about replacing them yet.MY08 Passat 2.0 TDI Wagon
Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
You could try looking at Bridgestone's Turanza range instead of their Potenza Range, though I think you've had enough of their tyres already. Likewise with Michelin (Primacy HP instead of Pilot Sport), Pirelli (Cinturato P7 instead of P Zero), etc.
As mentioned, make sure the tyre pressures are correct, as they are different from the sedan models. For a Passat Wagon up to MY2008, they should be 2.6 bar (38 psi) all-round for normal loads, and 2.8/2.9 bar (42/44 psi) front/rear for heavy loads.
The trick is to not get directionals, keep the pressures up (I run our customers' cars at 40 PSI), and to make sure your wheel alignment is spot-on.
The OEM-spec tyres always wear out fast. Turanzas are actually quite a good tyre, and offer a good compromise of grip Vs longevity.'07 Transporter 1.9 TDI
'01 Beetle 2.0
