Has anyone found their reverse light to be too dull to be practical, particularly in the wet? If so what's the solution? Is it possible to change out the rear fog light to make it clear and substitute as a 2nd reverse light?
R36 reverse light
I am also having the same problem in the Tiguan.
Looking at getting some LED bulbs with in-built resistors to increase light output but not throw a fault code.
Yes i will.
Might be best to check out oemplus/ecstuning/ebay to find some LED bulbs with resistors inbuilt.
Dull? reverse lights aren't there to light up behind the car. They're to advise others your car is moving backwards. So if the reverse light can be seen by others, then it's no only practical, it's doing exactly what it's designed to do.
Personally, the reverse sensors and outside mirrors are all I use to reverse as generally, I have a pretty good understanding of what's going on behind the car when I get into the car - especially since I don't walk up to the car with my eyes closed. So sensors and mirrors and short term memory are all you should need.
My caddy had awesome reverse lights - just an unobscured pair of 21W bulbs
now I'm in the passat I can't see where I'm going
You could pick up another inner tail from a LHD country so you have two reverse lights, but still it is not good
reverse camera is a good alternative
There are also people selling high-intensity LEDs who claim they work, but I am not experienced with those
It can be done, you need to remove the red lense and carry over a wire from the original reverse light.Originally posted by adrock View PostHas anyone found their reverse light to be too dull to be practical, particularly in the wet? If so what's the solution? Is it possible to change out the rear fog light to make it clear and substitute as a 2nd reverse light?
Alternatively, run down to Autobarn and grab a 50w globe that replaces the original. Here is the difference when using US spec Jetta inner tails:
"Reverse Driving Light" is the proper term the VAG uses. Argue with that.Originally posted by Rocket36 View PostDull? reverse lights aren't there to light up behind the car. They're to advise others your car is moving backwards. So if the reverse light can be seen by others, then it's no only practical, it's doing exactly what it's designed to do.
Personally, the reverse sensors and outside mirrors are all I use to reverse as generally, I have a pretty good understanding of what's going on behind the car when I get into the car - especially since I don't walk up to the car with my eyes closed. So sensors and mirrors and short term memory are all you should need.Last edited by maca; 02-09-2010, 02:52 PM.2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
Nope, no fault code at all. Just be weary of the heat the bulb creates compared to the regular one and check it regularly for any damage to the housing/clips.Originally posted by team_v View PostAwesome upgrade Maca.
Did the 50W globes throw a fault code?2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
Ahh okay.Originally posted by maca View PostNope, no fault code at all. Just be weary of the heat the bulb creates compared to the regular one and check it regularly for any damage to the housing/clips.
What are the stock bulbs rated at?
In your opinion of course Rocket. In over 45 years of driving I have laboured under the misapprehension that the reversing lights were there to actually illuminate where I was reversing to. I'm shattered.Originally posted by Rocket36 View PostDull? reverse lights aren't there to light up behind the car. They're to advise others your car is moving backwards. So if the reverse light can be seen by others, then it's no only practical, it's doing exactly what it's designed to do.
Or I can recall an 8" Hella QI reversing light on our rally car. Suppose that was to tell others we were reversing very F****** fast.
Suppose you have a good understanding of what's in front of the car too. and those xenons are there to tell others that your car is moving forward.
My short term memory is stuffed too...but I think that special number plate is still on hold till you return from Europe.Originally posted by Rocket36 View PostPersonally, the reverse sensors and outside mirrors are all I use to reverse as generally, I have a pretty good understanding of what's going on behind the car when I get into the car - especially since I don't walk up to the car with my eyes closed. So sensors and mirrors and short term memory are all you should need.You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
That makes perfect sense, only sometimes for a thrill I like to get all adventurous and reverse the vehicle after I've driven it to a new destination, BEFORE I have had the chance to walk up to it with my eyes closed.Originally posted by Rocket36 View PostI have a pretty good understanding of what's going on behind the car when I get into the car - especially since I don't walk up to the car with my eyes closed to assess the surroundings a little better.
You obviously don't get talk back radio where you are, otherwise you'd be too busy calling them to complain your neighbours air conditioner is too loud instead of posting your gems on here.
Thanks maca, might give it a try.Originally posted by maca View PostAlternatively, run down to Autobarn and grab a 50w globe that replaces the original.MY10 Silver R36 Wagon
VW Classifieds Username - VWC-adrock
IIRC, stock bulbs are 21w. So the updated bulbs are a significant improvement and basically have the power of a headlight. If only the reflectors were designed the same...2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
