Parking Brake Fault?
  • Parking Brake Fault?
    occasionally (not all the time) i seem to get a parking brake fault warning coming up on my MFD. Its happened both when i'm putting it on or taking it off.
    just wondering anyone else had these intermittent issues?
    is it worth taking it back (still under warranty) if it only occurs occasionally, though it seems to be happening more and more recently?
    Something to do with being slammed, perhaps?
    MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
    MY 2010 Skoda Scout Manual Silver -traded
      Not at all.
      Pre-'09 models had dodgey buttons. Take it into the dealer, and let them know. Most of them carry the switch on the shelf.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        i had a similar issue and when i approached the dealer i was told that it was not registering as a fualt so come back when it occurs. A bit disappointed given the cost of the vehicle and what i see a a trivial response.
        MY08 TDi 125KW Black Leather, Deep Black Pearl
          yeh from my limited experience with VW customer service it seems to be whack the computer on there and if theres no faults theres no problem.
          i got the same response with my gearbox troubles, though if they'd bothered to drive it theyd realise
            Sometimes, it doesn't log a fault code. Although, when it malfunctions, it's really quite obvious.
            '01 Beetle 2.0
              I've had the same thing happen in the last week. Does it make a difference if i change gear into drive with my foot on the brake then disengage the park brake compared to when i have my foot on the brake, disengage the park brake then select drive? It doesn't give me the warning in the latter scenario!
              Cheers,
              Jayse.
              The Fräulein: Black .:R36 Wagon...all boxes ticked!!
              The German Mistress: 2001 Black B5 A4 1.8T
                If it's a button failure, the EPB control module may release the park brake for you, by driving off. It wont re-apply it when you pull up, though.
                '01 Beetle 2.0
                  Originally posted by Umai Naa!! View Post
                  Not at all.
                  I had my R36 (delivered in June 200 in for the 25000km/2 year service yesterday - the park brake button was replaced. I hadn't noticed it acting up, but the computer was throwing out fault codes...
                  R36 =
                    I just had my 31,000km/2 yr service 2 weeks ago and the fault has only started this week...bugger.
                    Umai Naa, does it take them long to change over the faulty button?
                    Cheers,
                    Jayse.
                      I have had two parking brake buttons fail... both replaced under warranty.
                      First time it happened, the brake refused to release (couldn't go anywhere). Roadside assist disconnected the battery for 5 mins ... then restarted the car to get me going again.
                      Mk 7.5 Golf R
                        Ok there is a known fault with these. Even if you fit a new one it thats not enough. there is a superseded part number for the switch but if you fit it and try and clear the fault it will remain. You must do a terminal 30 reset to clear the fault. All good and not too much to worry about.
                        Done plenty
                        Jmac
                        Alba European
                          Cheers,
                          Jayse.
                          No, mate. Not at all. Probably a 30 minute turn-around.
                          Done plenty
                          Jmac
                          Spot-on, Jmac. The part number went from a B to a C.
                          '01 Beetle 2.0
                            I had a similar problem to this, they R&R'd the switch under warranty in about half an hour.
                            I can confirm the change in part number discussed above.
                            Tony.
                            2008 Passat 125TDI DSG, Leather.
                            2007 MkV Golf GTI - APR, 188kW, Leather, Manual.
