MY10 125, standard cruise control.
With cruise control active, briefly pressing the control lever up (to increase the set speed) increases speed to the nearest 10km/h value. For example, with the speed set to 101km/h, briefly pressing the control lever increases speed to 110km/h. If however the speed is set to 109km/h, it will still move up to 110km/h. If the lever is pressed up once again, it will increase to 120km/h.
The same happens in reverse when decreasing the set speed.
If I hold the lever up, it slowly increases the set speed until I release the lever.
In the manual it says pressing the lever briefly will "increase speed in small steps". A 10km/h jump is not a small step in my book.
Is this normal? If it is, can the amount be adjusted to say jumps of 2km/h?
Thanks in advance, couldn't find any info on this after searching the forum.
Cheers.
Cheers.
