R36 Brakes Vs R32 Brakes
The Fräulein: Black .:R36 Wagon...all boxes ticked!!
The German Mistress: 2001 Black B5 A4 1.8T
That cant be right! Thats the same diameter and thickness as the Bora 4motions front rotors and they're definitely smaller than the r32's! Must be in there by mistake.
Originally posted by VWR.3.2.GONE View PostNoticed on link spec sheet - why is there 2 sizes for front ?
312mm are tiny for the fronts !
Brake disc front (ATE 24.0125-0158.1)
Diameter: 312mm Vented
Finish: High-carbon Surface coated
Brake disc thickness: 25mm
Minimum thickness: 22mm
Height: 49.9mm
Centering diameter: 65mm
Inner diameter: 146mm
Brake pads front (ATE 13.0460-7184.2)
