Help......Wheel Specs Advice for Passat R36!
  • Help......Wheel Specs Advice for Passat R36!
    Hi Members,
    Need a bit of help as I've never had aftermarket wheels but know someone who is trying to sell a set of quality Advan Lightweight wheels. If size is right I may make an offer.
    The advertised is SIZE: 18X7.5, HOLE: 5, PCD: 114.3, OFFSET: +48 (225/40).
    I know R36s have the size of 235/40 18inch but will the above fit with the brake pads and not stick out of the arches???
    As you can see I'm a real newbie!! All the help would be appreciated!
    Thanks!
    BB R36 MY2010 Sedan ->Sunroof ->SatNav ->MDI ->DynaAudio -> LED Lights
    RAY
    Sorry Ray they are a Nissan fittment
    You will need wheels off a VW ,Audi etc Merc will bolt on too but depends on offset
    Your wheels are
    18X8.5, HOLE: 5, PCD: 112, OFFSET: +44
    Look here These should start you off
    MRR HR-2 custom wheels for Volkswagen Passat - WWW.RIMSNTIRES.COM
    VMR Wheels by Velocity Motoring - Aluminum Alloy Wheels for German Cars
    Hartmann Wheels - VW Wheels, stock replicas - hartmannwheels.com
    2010 R36 Sedan
    2007 Audi A4 B7 Cabriolet
    1997 R33 GTR Skyline V-SPEC ,2011 Harley V-Rod Muscle
      Thanks R34, I thought I found a bargain but looks like they weren't meant to be! hahaha
      RAY
        Actually the standard fitment for the R36 is 18x8 ET44.
        Your wheels are
        Raderwerks
          And on the end of that reply, will 18x8.5 work anyway?, What offset would you need to compensate? I've always thought that slightly chunkier wheels would look good.
          MY10 Black R36 sedan
          the silent assasin
            The wheels I'm getting are 19x8.5 ET38
            Basically they will sit out 12mm further on the outside lip and the same on the inside.
            VMR's have a 8.5 ET35 which is OK as well
            2010 R36 Sedan
              Yes, I went with 19x8.5 ET35 DPEs. I believe 35 is abt the lowest you can go.
