Hi All,
Just wanted to see if anyone has activated the DRL's on a VW Passat with OEM Bi-Xenon Headlights?
Vagcom / VCDS Byte 0 in 09 - Central Electonics;
- Byte 0 Bit 03 – Daytime Running Lights (Scandinavia) always active.
- Byte 0 Bit 04 - Daytime Running Lights (North America) only when handbrake off or car in gear.
All off the above work when the light switch is in the “0” position only.
As stated above, i have tried the (Scandinavia) and have found that my Low Beam (Xenons) are always on.
I have also tried the (North America) and have found that it works when the handbrake is released or the car is put in gear; which is exactley how I would like it to work, however it once again uses the Low Beam (Xenons) which I do not want to use!
Does anyone know how to activate the North American Style DRL, only using the "parking lights" instead of the Low Beam Xenon's?
Could it have anything to do with the Extra Function or Replacement Function as descibed in the following;
Jimmy has been helping me with this, however we have not explored futher than what is mentioned above.
Open to suggestions or advice!
