camber?
  • camber?
    what ways are there to make your tyres not have inner wear.
    a combination of adjusting:
    - the camber - relativeness of the top of the tyres vs the bottom of tyres - measured by a spirit level against the face of wheel- in an ideal world and even tyre wear world be achieved if tyres were vertical
    - the toe (relativeness of width of tyres at front to the rear); ideally again, equal front and back tracking
    but in reality you are probably looking for little bit of negative camber and a bit of toe in. factory would probably be a little bit of -ve camber (top of wheel further in) and toe in (front of tyres closer together than the rear of front tyres)
    when you get an alignment done at a tyre shop check that they will adjust both camber and toe (not just toe)
    \'95 Golf VR6
      so there is a way to adjust my camber and toe? without buying camber kits etc?
        Help here
        Look in the "Interseting Articles" forum
          toe, yes; camber - i would assume there is on your passat, as it is on all golfs - anyone else know?
          my thinking is that camber kits are for those cars that either a) are not camber-adjustable or b) so excessively dropped that they need extra!
          \'95 Golf VR6
            i'm still not sure what i'm supposed to ask for at the tyre shops..
            my fronts are angeled in abit more then the rear.
              Go to a reputable steering specialist and get a wheel alignment. Don't go to a tyre service.
              Adams at Padstow.
              Barry Solomon at Mortdale.
              There is a place around Sydenham also.
                would u have the address or phone for the barry solamons at mortdale, seems like the closest one to me.
                  The camber appears to be adjustable on a Golf 3.
                  To adjust the camber on a Golf 2, you need special bolts, part number N 101 740 02. These are the standard bolts for Golf 3. If not, C&S Auto has them.
