For those with the fitted RNS510 Sat Nav Unit I have they same problem that is also in every Tom Tom and Navman I have used. Would be good to see if anyone has got around this. (Both Swallowtail and I talked about this yesterday but couldnt find a quick fix)
The problem is that unless you know the exact suburb you are looking for you can search by street name alone. You may think this is stupid however its needed in many instances.
For example.. last weekend I was on the other side of town and needed the nearest Bunnings, so looked up the addy (in the iphone) and it was 1925 Gympie Road, Carseldine. So, in the GPS, start with Carseldine, then the road, Gympie, then the number... but guess what, it only goes to 1844 when we need 1925 and there is no way around it. Unless you know waht the next suburb is then you cannot find the exact location. This happens about 30% of the time in Brisbane, especially on longer roads where 3-5 suburbs share the same postcode. The system supposedly lets you choose by postcode but we couldnt seem to get that sorted either?
Garmin gets around this by allowing you to choose "all suburbs" at the start so you can then give the street address (even without the number if you dont know it) and it will display all the suburbs where that street exists, you then pick the suburb and away you go. Its such a simple thing to fix but there seems to be no way around in in the current system
Any ideas on a fix? How do other people get around this?
