How of curiosity, what pressure are we running on our tyres????
Tyre Pressure on R36!
Stick to the quoted pressures on the fuel flap sticker, VW and all other companys including the tyre manufactures spend millions on working out the correct pressure psi/bar to get the best ride, handling and wear out of the tyres for that certain car with that size/ rated tyres...Just make sure you check your pressures when they are cold if possible..........-VW-
Better performance, with no comprimises on tyre life.
I don't have a compressor at home, so it's a pain constantly changing tyre pressures when I go for a spirited drive. If I did have the compressor I'd probably run 41/40 for a softer ride and 44/43 for spirited drives.
