103kw or 125kw
  • 103kw or 125kw
    Hi all, i asked a while back about how to tell the difference between the 2 TDI models of passat, and was under the impression that the 125kw model has the TDI badge on the boot, but after visiting the local dealer, i test drove a 125kw passat with no badge. the dealer told me it was 125kw but i have no other way of telling that is was. and it was a 2007 model sedan.
    anyone got any ideas? or was this the way they came?
    also where are the compliance plates on them, i looked in the boot but couldnt find one
    ON my my09 the service schedule book has a sticker with the vin and other codes. on that it is printed 125kW TDI D6F . the compliance plate is in the drivers side door frame. my has tdi with the i in red.
    dunno re myo7
    good luck
    had a passat tdi. now mb c class.
      the first few letters of the engine number would tell you what engine code it is.
      Also yeah the build sticker on the car somewhere or the one in the service schedule would tell u how many kw as above
      FOLLOW US ON FACEBOOK
        so what is the engine code for the 103 and 125?
        i can then check this out
          my 125kw engine is coded BMN
          take a picture of the sticker (it should be in the boot under the floor) and post it here we'll tell you what it is if all else fails. theres a few different engine codes for the 103 and 125's if i remember correctly.
          2x Caddy, 1x Ducato
            i also see that there are different wheels between the 2 models, 16" on the 103 and 17" on the 125
              Try this link
              VIN Decoder
              It appears to be correct when comparing the data in the inside of my car service schedule. I note it does not include dealer fit items like the Bluetooth and ipod adapter... but that is nor surprising
              MY12 Volvo V60 T5 Tekink in Ice White
              MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
                Originally posted by richdave View Post
                Try this link
                VIN Decoder
                Thats pretty interesting. i checked my sticker and nothing is listed in option 4. - optional extras.
                so the leather,elec seats,xenons, park assist. etc are just not listed at all. is this just mine or arent they listed?
                  The vin # only tells you that your car is a vw passat, where and when it was made and its serial #. If you want to see what is in your specific car look at the sticker in the boot as i already said.
                  2x Caddy, 1x Ducato
                    The sticker you refer to is the same as the one on inside of service schedule cover has all the PR codes. These should identify the FACTORY fitted items.
