Pics of the R36
  • Pics of the R36
    Well Saturday was fine and Sunny, gave the girl a wash and took some pics.
    Hope you like - Quality of my camera work leaves a lot to be desired!
    Tints set it off nicely I reckon (and work a charm when it gets hot!).
    Confirmed Global Warming Sceptic. No Longer a VW Owner -Loving my new 2011 Range Rover Sport - bought as VW unable to provide info on the new Toureg despite it being released overseas 12 mths ago. 2008 R36 Wagon, 2006 GTI and 2004 R32 - Gone. Sorry VW, you make great cars but until you improve your customers' experiences you will lose customers
    Well aren't you a lucky bugger! That's gorgeous.
    2000 Mk IV GTI
      Beautiful man, beautiful!
        NICEEEEEEEE! love it!
          Congratulations. Looking good!
            absolutely awesome car, i'd get the wagon too
            how does it drive?
              Very nice
              I'm forever washing/getting ours washed... it's a very dirty colour
              R36 =
                how does it drive?
                It is going really well.
                I have only taken it out on the highway a couple of times since I picked it up in June, but on the highway it really comes into its own. The car is balanced and perfect for overtaking on single lane country roads.
                I have now put 4,500 kms on it, and it feels like it has finally loosened up a bit. It is still deceptive in its speed, gets going with a minimum of fuss, and the exhaust note and engine noise is enjoyable without being intrusive.
                The Xenon lights are great, even in the fog (R36 doesn't have Foglights).
                My only slight dissapointment is fuel consumption. It it around 12l/100km in town, which is respectable given I drive 12kms into the city at a crawl every morning. However on the highway at (GPS indicated) 124km/h the tacho is sitting above 3000rpm and the fuel cons only gets to 9.9l/100kms.
                In contrast my last car (MkVGTI) went from 11 in town to about 7 on the highway.
                Nevermind, the car is such a blast to own I am happy to part with the extra $$ to enjoy it.
                  3000rpm at 124kmh?? That is only 41kmh/1000rpm. The 3.2lt is about 49kmh/1000rpm. Are you sure you're not in 5th instead of 6th?
                    In "D" and showing 6 on the MFD
                    In your figures using numbers as indicated on the speedo or actual speed?
                    When I use my GPS, at speedo indicated 125km/h I am only travelling around 117 according to the GPS.
                    At GPS indicated 125, the speedo is nearer 135km/h.
                    I know the speedos in most VW's are out by about 10%, and the GPS is dead accurate (once a constant speed is maintained),
                    This has been confirmed by roadside speed indicators (at roadworks sites etc.), as well as by setting the cruise on a flat road, resetting the MFD, and getting an average speed from the trip computer.
                    Funny that the cars electronics know the exact speed, but cant make the speedo show it!!.
                    This problem was also the case with my MkV GTI, and my brothers 2.0FSI Golf.
                      I have calculated the gear ratio, final drive, tyre circumference and engine rpm, and get - from memory - about 49km/h per 1000rpm, which tallies quite closely to the speedo.
                      The speedo in the Passat is about 5-6% out, not 10% as far as I know.
                      I would say that road side speed indicators are not so accurate.
                      As for calculating the speed by measuring the distance and then dividing by the time taken, this will be more accurate as the speedo needle requires a certain amount of "slippage" in order to show speed. It has to "slip", otherwise it would wind off the clock. The odometer is different in that it is "hard wired" to the gearbox in that there is a sensor that counts revolutions - no "slippage" - and then calculates distance by using the tyre diameter x revolutions.
                      I therefore find it strange that your speedo would indicate 124kmh at 3,000rpm when my Passat, with the same gearbox and theoretically the same final drive, indicates at around the 100kmh mark and 2,000rpm! If I was indicating 3,000rpm in my Passat, I would be travelling at an indicated 150kmh, which *maybe* about 141kmh if you take into account the "error".
                        I respectfully disagree - I only know what my car does, and the amount it (and the GTI before it) was out in the speedo dept - cannot speak for your car.
                          I can't remember... is your car one with or without the reversing camera?
                          I ask because I got a call from Volkswagen today, saying they hadn't found an acceptable retrofit option but will instead give me $1500 to make the problem go away. Proper Bluetooth will be doable in the second week of October (the week after I leave for four months!)...
                          R36 =
                            Speedo Error
                            On the F3 you can do a 5km distance check of your odometer / speedo. I have timed the 5km run doing a constant 'indicated' speed and then worked out my 'true' speed.
                            After indicating 120km/hr over 5km, my 'true' speed was 116km/hr.
                            Most cars under read like this, for the obvious liabilty / arse covering reasons, i presume.
                            VW don't seem to be overly out here.
                            RIP! 2007 Passat 3.2 4Motion Black Sedan | 19"s | AVC-9000 | Audi A3 Sportback 2.0TFSIQ
                              Gear Ratios
                              Hey Lance,
                              Dreamer's "GPS" speed of 124km/hr is probably more like 128km/hr on the dial, so a smidge over 3000rpm in 6th is about right i reckon.
