G-8VXWWTRHPN need info on 76' passat wagons - VWWatercooled Australia
  • need info on 76' passat wagons
    well i have been driving past this orange 76 passat wagon everyday after work and have finally left a note on the window asking them if they would like to sell it. it just sits there and i have never seen it move. what can u do to these puppies? are parts readily available? can u get coilovers for them? is it going to need a bigger money tree than the mk1? here are some pics taken with my phone.
    iirc, it was for sale a while ago, in richmond maybe (somewhere inner city like) for about 1500 I think. it was on carsales.
    I wanted to go have a look at it at the time, but didn't have the cash,.
    auto or manual? looks in pretty good nick.
    I don't think you can get coilovers (not that I know of) but some parts will be really difficult (small trim bits etc) but alot of the mechanical parts are all golf stuff
      auto.. yeah pretty good nik. small dint on driver side front quarter and a plastic bumper end missing. reckon it would look great slammed on some phat wheels. it is sitting on the side of the road over near brunswick east, probably the same one.
        i know that car.
        was at Volkspower getting a RWC some time ago. Looks pretty clean and tidy.
        they will be harder to get parts for, but dam they are cool!
          theyre fun to get parts for Ive had mine for a while and few times people have come up to me out of nowhere and offered me parts
          so far Ive got 3 front guards a bonnet 2 bumpers a towbar and a water pump off complete strangers never seen anything like it
          a lot of golf and audi stuff fits em but mine is a real early full import and alot of things are wierd ebay is good and theyre pretty fast cause theyre really light about 900kg for a coupe
          early audi 80s / foxs are much the same
            Parts really aren't a problem, usually always available from some fellows in Germany. Its identical to the Audi Fox except for the rear end. Alot is changeable with the B2 Audi 80 and US Volkswagen Quantum and Brazilian Volkswagen Fox upto 1993.
            Alot of rubber bushing and other engine parts are still used on the 2010 Brazilian Volkswagen Gol / Parati. I ordered new sway bar mountings from the 2010 Parati and they are identical to the 1976 part!
            There are no rear coilovers, as the Passat uses a separate spring/damper unit. best you can get is Bilstein B6 monotube and custom springs, or convert to air-bag suspension. There are writeups on the VW/Audi B1 community "Dasher Owners Group" (Passat was named 'Dasher' in USA)
            http://dog.mp3equipped.com/dog/
              VW Passat Bits
              I Have Sum Bits left over for Sale.. INCLUDING A RARE MESH VISOR THAT will also fit a MK1 GOLF
              And Can Get Hold of more bits too.... Cheers G...
                Would you happen to have a unmolested woodgrain insert for the dashboard? Many of them have holes cut in them for radios..its a difficult RHD part to obtain!
                  that would right!!!! I chase prts up hill and down dale and know you all come out of the wood work!!!!!!!!!!!!! Parts for a '74 LS sedan anyone?
                  Old Skool Passat Power Rules!!!
                  1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
                    Passat parts available, and or whole car
                    For anyone who likes these cars, I have a 1980 diesel wagon in Kermitage Green (aka Santos Green), with a LOT of parts, to go to someone in a month's time thereabouts. I have been messing with Passats for about 15 years or so, and it's nearly time for me to transfer to something else.
                    Unfortunately I don't have a regular access to the web, and people would have to call me on my mobile for the details, so its not much use posting me a reply...sorry bout that.
                    My no is 0408 514 180,
                    and I'm based in Brisbane.
                    Regards,
                    Tim.
                      What parts are you after vinderliker?
                      Most likely someone on Dasher Owners Group would be able to help..
                        Hi Alex,
                        I am after interior stuff at the moment, glovebox, under dash paneling and a centre counsole, blue door panels and new window winder. I might be able to source some stuff around Canberra from A&R or Volksparts, but I am always on the lookout for stuff. I also want to get a TS steering wheel, but I know someone who has one I just need to get the dollars together. Since I have had the car from around Xmas 2005 I have replaced just about anything with the drive train including the engine, carb, exhaust, springs, shocks, pads etc, I virtually have a new second hand car.
                        The last sort of mechanical thing i may need is a set of front springs and maybe a brake upgrade, although I can get them here in Canberra for about $410. I have had a few people say to me that they have parts but have not got back to me.
                        James
                          I have a spare center console that goes over the gear selector (but not the section where the three aux gauges go). Door trim panels i can probably get, but the vinyl would have to be dyed (as it is beige). Window winders i have somewhere, they are the type without the chrome insert.
                          Regarding the brakes, depends if you want to upsize or just want better standard brakes. I personally chose Audi 80 B2 239mm vented carriers and bought the calipers new from the USA. These are much nicer then the ATE units and have a greater pad surface area. The master cylinder is being upgraded to the USA Audi 5000 (Audi 100) 22mm unit part number 431 611 019K and the accompanying 7" booster that requires a new clevis extended by 15mm (part 443 721 213). Hopefully those parts all suitable, i'll know soon enough!
                            Thanks for that Alex. I have a think about what I need. I have to watch the dollars at the moment as i have already spent so much on the car.
